Fifteen minutes after starting the engine starts to overheat?
132,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
DANDICKTEN41
The coolant reservoir is full. The thermostat is new.
Dec 28, 2023 at 5:40 AM
  • 55,694 POSTS
When the engine is overheating can you hear the cooling fans come on? If not, this is your problem. I would check the fuse #12 in the fuse panel under the hood for the cooling fans first.
These guides can help:
and go over this guide as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Here are the radiator cooling fan wiring diagrams so you can see how the system works. Check out the images (below). Please let us know what happens.
Dec 29, 2023 at 3:23 AM
