Overheating
60,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
JEEP2007
My car overheats while driving. I can let it idle with the air conditioning on for over an hour and it does not overheat fans kick on high. I have changed the thermostat and water pump and still has not fixed the problem i do not know what to do.
Jul 9, 2017 at 12:18 PM
HMAC300
  • 48,601 POSTS
when hot disable fans if electric then check radiator for cold spots if any it is bad. Then check for a blown head gasket.
Jul 9, 2017 at 11:40 PM
