Overheating
220,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
HERBERT STRIRK
I had a pipe leak in the rubber to the radiator.
It got fixed.
Recently I had a big oil leak.
The mechanic had to handle the cylinder head, put a new radiator in.
When the car got hot, 1 mile it poured out coolant.
They replaced the radiator cap and fixed it yesterday.
Today after about 5 KM. steam came out from under the bonnet. Coolant all over.
I had to get it back by tow truck to the mechanic.
What causes this.
Thank you, please answer.
Herbert Strirk
Sep 20, 2021 at 9:52 PM
SQM
  • 6,383 POSTS
Did the engine over heat before getting steam from under hood/bonnet?
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
When an engine over heats it can blow out the radiator or any other coolant hose due to excessive pressure. It can also vent coolant out of the radiator cap, when the pressure exceeds the limit of the cap.
Were you able to see where the coolant was coming out of?
https://www.2carpros.com/articles/car-is-leaking-coolant
Please let me know what you are experiencing.
Sep 20, 2021 at 11:48 PM
HERBERT STRIRK
I said to the Mechanic, Google said it is the thermostat. The Mechanic said, " Who is Google". They again changed the radiator cap, then the water pump. Eventually they changed the thermostat. Then it worked.
Sep 28, 2021 at 3:21 AM
HERBERT STRIRK
The problem is solved. Eventually they changed the thermostat.
Sep 28, 2021 at 3:23 AM
SQM
  • 6,383 POSTS
This is great news that the thermostat fixed the issue. Appreciate you letting me know.
Sep 28, 2021 at 3:33 AM
