Overheating
150,000 MILES
CIVI MAN
Hello, two days ago my car has been overheating. I picked up a new thermostat and out it in. I have no heat at all. Still gets hot, coolant was bubbling from over tank but when I pushed down on the radiator cap it stopped, but soon as I let go of it it started again. Do you think i need a new cap? Other then that it runs great.
Dec 22, 2018 at 6:55 AM
Good afternoon,
Yes, it could be the cap.
My concern is the bubbling. it may have a damaged head gasket and it is leaking compression into the cooling system. that would also explain the no heat as well.
Dec 22, 2018 at 7:41 AM
ALEX19899
  • 171 POSTS
My honda civic had the same issue. I had to replace the head gasket unfortunately.
Jan 8, 2019 at 12:28 PM
Before assuming a head gasket, replace the cap and re test.
Then if it still does it you will need to get a leak down test done to confirm the gasket is leaking. Then you can feel confident that is the issue without guessing.
Jan 8, 2019 at 7:33 PM
