Overheating
140,000 MILES • 2.2L • 6 CYL • AUTOMATIC
SHERILYN FRANKLIN
  • 90 POSTS
After my car has been running for a while the fluid in my antifreeze overflow jug starts boiling.
Nov 15, 2019 at 7:43 AM
94 TRANSAM
  • 680 POSTS
Welcome,
It sounds like your thermostat may be stuck closed.
You will find it under the cap at the end of the upper radiator hose. Simply unbolt the cap, lift it up. Pull old thermostat and put the new one in and rebolt the cap.
Let me know if this helped.
Rich
Nov 15, 2019 at 12:14 PM
SHERILYN FRANKLIN
  • 90 POSTS
Do you have pictures showing where the upper radiator hose is located?
Nov 15, 2019 at 1:08 PM
94 TRANSAM
  • 680 POSTS
I don't have an online manual that show the hose ,but if you open the hood and face the motor it will be a big black hose about 1.5" in diameter on the right that runs from the front of the car to the top of the motor.
Here is a guide on how to do it step by step:
Rich
Nov 15, 2019 at 2:52 PM
