After my car has been running for a while the fluid in my antifreeze overflow jug starts boiling.
Friday, November 15th, 2019 AT 3:43 PM
94 TRANSAM
MECHANIC
Welcome,
It sounds like your thermostat may be stuck closed.
You will find it under the cap at the end of the upper radiator hose. Simply unbolt the cap, lift it up. Pull old thermostat and put the new one in and rebolt the cap.
Let me know if this helped.
Rich
SPONSORED LINKS
Friday, November 15th, 2019 AT 8:14 PM
SHERILYN FRANKLIN
MEMBER
Do you have pictures showing where the upper radiator hose is located?
Friday, November 15th, 2019 AT 9:08 PM
94 TRANSAM
MECHANIC
I don't have an online manual that show the hose ,but if you open the hood and face the motor it will be a big black hose about 1.5" in diameter on the right that runs from the front of the car to the top of the motor.
