When the car is in motion it starts to overheat?
150,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
K.KENDRICK
I just replaced the thermostat and when the car sits idling it stays at the halfway point once my car is in motion it starts to overheat. What could be this problem?
Oct 13, 2023 at 8:34 AM
  • 110,251 POSTS
Was it overheating prior to replacing the thermostat? I ask because you may have gotten air into the system which is causing a blockage. Don't laugh, but does the heater work?
On the other hand, this could be related to a faulty head gasket. Take a look through this link and let me know if anything mirrors what you are experiencing.
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Also, take a look through this link. It explains what to look for.
Let me know your thoughts.
Oct 13, 2023 at 2:41 PM
K.KENDRICK
Thank you, Joe, for replying to me so quickly... There are bubbles in the coolant when I take off the radiator cap, but is that a definite blown head gasket?
Oct 13, 2023 at 2:59 PM
  • 110,251 POSTS
If the bubbles are constant, chances are there is compressed air from the combustion chamber making its way into the cooling system.
When you say bubbles, do they look like the ones in the link I sent? If they do, you should do a chemical test to see if there are exhaust fumes present. (See step 4 in the "Head Gasket Blown Test" above)
Let me know if you are comfortable performing that test. Also, if you could get a few pics of what you are seeing, it may help.
joe
Oct 13, 2023 at 3:11 PM
K.KENDRICK
Hello Joe,
The bubbles are like the ones you would see in a pan of simmering water on the stove. In between a simmer and a boil.
Oct 13, 2023 at 5:09 PM
  • 110,251 POSTS
If that is happening when the engine is cold or warm, we need to do the chemical test in the link above. It shouldn't be doing that. I suspect we have a head gasket issue.
Let me know if you are able to do the test.
Oct 15, 2023 at 6:26 AM
