overheating
2007 PEUGEOT 207
63,000 MILES
NATHUGHES88
hi my car keeps overheating, when I took the cap off it boiled over but I think was because the car had only just stopped running. I did notice though that the water that was coming out of it was a reddy colour. also now the car is at a stand still it is leaking. I have made sure there is water in it and the oil level is fine to. what could be the problem?
May 26, 2013 at 10:36 PM
could be the thermostat, clogged radiator or a head gasket failing from the overheating
May 26, 2013 at 10:51 PM
NATHUGHES88
someone has just told me to check if there is yellow sludge in the oil and if so it was the head gasket I have just looked now and the oil seems fine. what do I do for a clogged radiator?
May 26, 2013 at 10:59 PM
it would have to be removed and power flushed
May 26, 2013 at 11:00 PM
NATHUGHES88
I have just been out to it again and I have noticed that the part you put water in is empty again
May 26, 2013 at 11:10 PM
