Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Daewoo
Lanos
Engine
Symptoms
Overheat
Overheating
2000 DAEWOO LANOS
80,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DIPPIES
MEMBER
1 POST
Fans come on at boiling point if i unplug fan switch on cylinder head fans come on heat gauge stands on below normal.
Nov 6, 2019 at 6:38 PM
Experienced Mechanic
Good morning,
By removing the plug, it sends a hot signal to the ECM and the ECM commands the fans to come on.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Sounds like the switch that you disconnected may be the issue or the thermostat may be the issue.
Images (Click to enlarge)
Nov 6, 2019 at 6:50 PM
DIPPIES
MEMBER
1 POST
Why shows heat gauge below normal but water temperature is at boiling point?
Nov 8, 2019 at 7:46 AM
Because of where the sender unit is located.
Did you replace the thermostat?
Nov 9, 2019 at 4:44 AM
DIPPIES
MEMBER
1 POST
On Daewo Lanos how do you bleed air out of cooling system?
Nov 11, 2019 at 4:20 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
