Severely overheating
217,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
ANGEL CLAY
it is overheating so bad that I can feel it in the gas pedal. It is real real sluggish it is like it doesn't want to go. I just replaced the water pump, but I did not replace the thermostat. could that have something to do with it or could it be the catalytic converter or something completely different? I am a single female that knows nothing about vehicles. can you please try to point me in the right direction.
Apr 5, 2019 at 2:52 AM
Good afternoon,
Yes, it could be the thermostat. That is a common reason for overheating.
My concern is from the overheating, you may have damaged the head gaskets. That would require major engine work to repair.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Apr 5, 2019 at 3:53 AM
