cooling fans wont turn on?
200,000 MILES
TONYA333
The fans wont come on and it is over heating. it has new water pump, no thermostat and kills battery when it is hot. I cannot figure out what is going on. it is leaking by the EC valve.
Oct 21, 2016 at 5:55 AM
HMAC300
  • 48,601 POSTS
have coolant system pressure checked for leaks you may have a leak from your work. also check resistance of coolant switch. since you did not give engine size we cannot give you the location and resistance of switch/sensor.
Oct 28, 2020 at 11:09 AM
RENEE L
  • 1,260 POSTS
Hi TONYA333,
Please get back to us with your engine size so that we can further assist you.
Thank you for visiting 2CarPros.
Sincerely,
Renee
Admin
