Overheating, any suggestions?
130,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GARYONGARY
Fans not working. Car overheating.
Wired fans to battery, they work. Still running little hot. And suggestions?
Aug 16, 2022 at 12:03 PM
  • 110,244 POSTS
First, when the engine is cold, remove the radiator cap and make sure the coolant level is full. Don't rely on the coolant reservoir.
If the fans are running and it is still running hot, then I would suggest replacing the thermostat and flushing the radiator. I don't know if you have already done this or not. However, that is where I would start.
Here are two links. One explains how to flush the radiator and the other explains how to replace a thermostat.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Aug 16, 2022 at 2:06 PM
