overheating
115,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MPARSONS
Antifreeze blowing out the overflow tube. Gage temperature reads about 220 degrees. I suspect the thermostat.
Jul 7, 2016 at 10:27 AM
JIS001
  • 3,412 POSTS
if you suspect the thermostat then when it is overheating check your upper and lower hose. The upper hose will be hot and lower hose cold.
Jul 7, 2016 at 11:47 AM
