Overheating?
2017 NISSAN TITAN
65,000 MILES • 3.6L • V8 • 2WD • AUTOMATIC
MATTHEWJON
  • 10 POSTS
The truck listed above continues to overheat even after replacing the thermostat housing and the water pump. No coolant leaks that appear under the vehicle only loses out overflow tank.? any suggestions
Jun 3, 2023 at 12:54 PM
  • 110,236 POSTS
How quickly does it overheat? Also, does it overheat if you are driving at highway speeds?
Let me know that. Also, when the engine is cold, remove the radiator cap. Make sure it is full first. Then, start the engine to see if the coolant starts coming out.
Let me know what you find.
Jun 4, 2023 at 3:35 PM
