Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
LS
Engine
Symptoms
Overheat
Overheating
2002 LINCOLN LS
156,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
STACYLYNN7
MEMBER
My vehicle listed above overheating had codes read said thermostat. changed still overheats.No leaks.thinking it is the water pump.
Feb 2, 2020 at 10:10 AM
Experienced Mechanic
Good evening,
What were the codes? Codes do not identify bad parts, just failed systems.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
This could be a water pump but needs to be tested to see if there is circulation.
Did you check the cooling fan motor to see if it is working?
Images (Click to enlarge)
Feb 2, 2020 at 10:45 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
