Overheating
200,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
AUSKIP17
I started having an overheating issue so I replaced my thermostat sensor, thermostat and thermostat housing. Flushed and refilled the system using a hose. Refilled and bled the radiator. It only seemed to take under five liters of coolant. I drove the car around when the check engine light came on and the temperature gauge rose up. I am not sure what it could be other than a blocked radiator. Any help please. Corey.
Jul 9, 2016 at 2:29 PM
WRENCHTECH
  • 20,760 POSTS
I do not know why you assumed a thermostat was the original problem. That is not very common. At this point you likely still have air pockets in the system that need to be worked out. Once the system is completely full you need to pressure test the cooling system for leaks.
Jul 9, 2016 at 9:33 PM
RENEE L
  • 1,260 POSTS
Hi AUSKIP17,
Here is a link to an informative article from this site that explains and shows you how to check your cooling system yourself. I have also included a link to one our 2CarPros YouTube video explaining how to pressure check your coolant system. If you need any further help please come back to 2CarPros as we are always happy to help.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://youtu.be/W8kra65m15c
Kindest regards,
Renee
Admin
Jul 10, 2016 at 7:45 AM
