So, my truck starts up and the inside thermostat slowly starts going to almost max temperature and just sits there the entire time I drive it, but then I'll pull over after like 25 minutes of driving it on that supposed heat. I take the radiator cap off and it should explode on me, but it doesn't, it has normal pressure. I also changed the thermostat in the engine and it had a f*** ton of rust and dirt and I cleaned it out and it still says it's running hot, and the radiator isn't just holding water but it isn't losing a lot of water at the same time, so if someone could please help me, I'm starting to think it's either the inside thermostat or a sensor or something.
Oct 18, 2023 at 7:18 PM
