Overheating
214,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
DLABONTE
It has never overheated before. Last week, while in stop and go traffic on the freeway, my water pump broke. I got off at the next off ramp, which took about ten
minutes. It did not get into the red zone and did not over boil. I had a mechanic
replace the pump and thermostat. On my way home it started to overheat
and get close to the red zone. By turning my heater on full blast I was able to
keep it in the normal zone. On my way back to the mechanic the next day, it
ran hot again. I kept the heater on full blast so that it stayed in the normal
zone. He changed by radiator but I still had the same problem. He suggested
changing the radiator fan, which I will do but I do not think it will solve the
problem because it seems to be kicking in when it is supposed to. There is no
oil in the coolant reservoir tank or milkiness in the oil but I am concerned it is
the head gasket. Any thoughts? Am I missing something obvious?
Aug 9, 2018 at 7:49 AM
  • 110,246 POSTS
Since the problem has not been solved with a new pump, thermostat, and radiator, that does not leave too much. Since the fans are turning on when they should, I agree with you. Replacing a good fan is not going to solve anything. I assume the cooling system has been properly filled and bled.
The water pump on your vehicle is driven by the serpentine belt (accessory belt) which also drives the alternator, AC compressor. Check to make sure it is tight and not allowing the water pump to turn slow. Also, it is even possible to have the belt routed incorrectly. Here are the directions for removing and replacing the belt. It includes a picture of the belt tension-er and its specifications along with the routing diagram.
REMOVAL
NOTE: The belt routing schematics are published from the latest information available at the time of publication. If anything differs between these schematics and the Belt Routing Label, use the schematics on Belt Routing Label. This label is located in the engine compartment.
CAUTION: DO NOT LET TENSIONER ARM SNAP BACK TO THE FREEARM POSITION, SEVERE DAMAGE MAY OCCUR TO THE TENSIONER.
Belt tension is not adjustable. Belt adjustment is maintained by an automatic (spring load ) belt tensioner.
1. Disconnect negative battery cable from battery.
2. Rotate belt tensioner until it contacts its stop. Remove belt, then slowly rotate the tensioner into the freearm position. (Fig. 3).
INSTALLATION
Belt tension is not adjustable. Belt adjustment is maintained by an automatic (spring load) belt tensioner.
1. Check condition of all pulleys.
CAUTION: When installing the serpentine accessory drive belt, the belt MUST be routed correctly. If not, the engine may overheat due to the water pump rotating in the wrong direction (Fig. 3).
2. Install new belt (Fig. 3). Route the belt around all pulleys except the idler pulley Rotate the tensioner arm until it contacts its stop position. Route the belt around the idler and slowly let the tensioner rotate into the belt. Make sure the belt is seated onto all pulleys.
3. With the drive belt installed, inspect the belt wear indicator (Fig. 4). The gap between the tang and the housing stop ( measurement A ) must not exceed 24 mm (0.94 inches).
____________________________________________________________
If everything checks out good, do this simple check. When the engine is running and at operating temperature, inspect the upper and lower radiator hoses to make sure they are not collapsing. If they check good, that is about the extent of the cooling system. However, keep in mind, a bad head gasket can cause a heating up issue. Here are a couple links which talk about symptoms and how to check for a bad head gasket. I realize you are not seeing the mixing of oil and coolant, but that does not always mean there is not a leak. Exhaust gases can get into the cooling system causing problems. Take a look through this link. It discusses the symptoms as well as how to check.
Aug 10, 2018 at 1:11 PM
