Overheating
198,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
HELPMYONDA
My car misfires on one cylinder and overheats in about twenty minutes while I drive it. I pressure tested the radiator and the pressure goes away in about three minutes and there is never water in the radiator even after I fill it up it leaks out.
Help
Jul 23, 2018 at 10:48 AM
  • 31,937 POSTS
You need to get a head check done, this is a quick and simple chemical test to determine if there is any combustion leak into the cooling system. This can indicate a blown head gasket. A compression test on the misfiring cylinder will also be a help and a visual indication of coolant in the cylinder is a dirty brown stain on the spark plug. Start with the head check a mechanic can do this test in just a few minutes, often while you wait. Post back with the findings for further advice.
Jul 23, 2018 at 12:24 PM
RENEE L
  • 1,260 POSTS
Hello HELPMYONDA,
Here is a link to an article form this site that features written step by step instructions, pictures and a video explaining how to conduct a compression test:
If you need further instructions or have another question please come back to the site, we are here to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jul 24, 2018 at 7:12 AM
