Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Firebird
Engine
Symptoms
Overheat
Overheating
1997 PONTIAC FIREBIRD
96,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
KMRITZ41
MEMBER
My car keeps overheating. I changed the thermostat, radiator cap, checked for leaks, and flushed the system.
Jul 10, 2020 at 9:47 PM
Experienced Mechanic
Good morning,
Since you have overheated often, you may have damaged a head gasket in the motor.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
I would do a leak down test for each cylinder. Remove all the plugs and add shop air to each cylinder. Watch for any movement in the cooling system. If you see movement, that is a head gasket leaking.
Jul 10, 2020 at 11:37 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
