Overheating
141,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
GMAN222
The car overheats. I have replaced a radiator, thermostat, water pump. The car still overheats. I did flush the lines and bled the air out. I did notice steam coming from the back of the reservoir last night. I have not checked the fan yet. I am
desperate for help. Are all the hoses supposed to be hot to the touch? Thanks for any help.
Jul 24, 2017 at 7:42 AM
  • 55,579 POSTS
Yes the cooling fan must work or the engine will over heat. Turn the air conditioner on and the fan should come on within thirty seconds.
Here are a couple of guides to help you get the problem fixed.
https://www.2carpros.com/articles/replace-electric-fan-motor
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Cheers, Ken
Jul 25, 2017 at 6:56 AM
