Randomly overheats
207,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ANCHORSAWEIGH
Truck randomly overheats, becoming more frequent.
Truck has appropriate level of coolant(mostly water at this point)
when truck is starting to over heat and I turn on the heater it will sometimes blow cold air and the truck will continue to overheat .If I toggle the air and or temp controls sometimes the air will heat up and the temp will return to normal.
when the temperature rises to overheat I can shut off the truck and restart in a few minutes and the temperature will drop back to normal before the system has had a chance to cool.
I feel that the issue may be an air lock ,sensor or control valve. I have also changed the thermostat- no change.
sometimes I hear a hum like a fluid restriction under the hood near the firewall in the vicinity of the heater and control area.
Any advice would be greatly appreciated.
May 19, 2019 at 2:30 PM
  • 55,710 POSTS
It sounds like you have a blown head gasket. To confirm the failure here is a guide to show you how to perform the test:
May 21, 2019 at 7:16 AM
