Overheating
200,000 MILES • 4.4L • 4 CYL • 4WD • AUTOMATIC
ROSETTA PERKINS
My car is running I went to autozone and put some antifreeze in it ran for awhile when it sit for awhile it start up I drove it home because it start knocking not very bad I was afraid to drive it anymore but when we look under the hood water was splash out but couldn't see Wher it was coming from
Nov 23, 2016 at 11:42 AM
WRENCHTECH
  • 20,760 POSTS
You could have already done serious internal engine damage by driving it with a cooling problem. You need to have the system pressure tested to locate and repair the leak.
Nov 24, 2016 at 6:09 AM
ROSETTA PERKINS
Where can I get the pressure check what type or tool do I need
Nov 24, 2016 at 10:12 AM
WRENCHTECH
  • 20,760 POSTS
It's a hand pump that connects to the radiator. Some auto parts stores will loan or rent them.
Nov 24, 2016 at 10:14 AM
ROSETTA PERKINS
Do the car need to be running when Itest it with the pump do I put more antifreeze or water before starting the car
Nov 24, 2016 at 10:26 AM
WRENCHTECH
  • 20,760 POSTS
It needs to be full of coolant but the engine won't be running.
Nov 24, 2016 at 10:28 AM
