My truck is constantly overheating
427,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CHARLES RODGERS
I can't figure out why. I have replaced the thermostat, water pump, and hoses. I tore down the motor and flushed it out I have also flushed out the radiator, put some stop leak and it still overheats. Can you help me?
Feb 24, 2020 at 1:07 AM
Good afternoon,
First, the stop leak was a very bad idea. It does nothing but clogs up the radiator and heater core.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Did you change the thermostat? What temp did you use when you changed t?
I would also do a leak down test to be sure a head gasket is not leaking compression into the cooling system super heating the coolant.
Feb 24, 2020 at 8:04 AM
