Overheating
174 MILES • V6 • 2WD • AUTOMATIC
RAZORBACKS
I have replaced all intake gaskets, manifold gaskets, battery, starter, fuel filter, the extra sensor, and now it is running hot! Which when I got it out of the shop it was running between 100 and 210. Whati s the issue?
Nov 5, 2017 at 10:09 AM
  • 55,766 POSTS
It sounds like you may have a blown head gasket or a stuck thermostat.
Here are three guides to help you confirm the problem so you can get it fixed:
and
Here is a general guide on overheating that can help as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please run this test and get back to us.
Cheers, Ken
Nov 6, 2017 at 6:43 AM
