Overheating
124,000 MILES
DEWAHN LEMAR GREENE SR.
Engine is overheating, coolant gone. no white smoke, no bubble in coolant just overheat and no coolant.
Sep 25, 2020 at 3:29 AM
Good afternoon,
You will need to pressure test the system and check for a leak. If you find nothing external, then look at the oil level and see if the level increased.
https://www.2carpros.com/articles/radiator-pressure-test
It may be leaking into the oil pan.
https://www.2carpros.com/articles/car-is-leaking-coolant
Sep 25, 2020 at 5:55 AM
