Engine is overheating, coolant gone. no white smoke, no bubble in coolant just overheat and no coolant.
Sep 25, 2020 at 3:29 AM
✓Experienced Mechanic
Good afternoon,
You will need to pressure test the system and check for a leak. If you find nothing external, then look at the oil level and see if the level increased.
