I already change the radiator. replace the fans, thermostat, hoses and still it heats up.
Jan 14, 2017 at 11:12 AM
JOHNNY G.JR
✓Experienced Mechanic
Look in radiator for possible combustion gases. Test your compression on cylinders for possible head gasket failure. Are you losing any coolant and cannot find the source? Any steam coming out exhaust?
Jan 14, 2017 at 11:43 AM
STEVE W.
Is there any sign of leakage in the water pump weep hole below the thermostat housing?
