Usually within a mile after a cold start after a minute or so of warm up. This is an ongoing problem.
Work that was done: replaced T-stat, replaced water pump, had head gasket checked (it was okay). Replaced drive belt. All hoses okay. Cooling fans had issues but fixed to run full time. Heaters work normally and put out hot air.
Naturally the next step is replacing the radiator. But after reading a few of the Q&A here and other car sites, I am suspecting the coolant itself. Currently has DexCool in it which can cause blockage.
So, my Question is, 'Can a flush and fill and replacing the DexCool with Prestone Green coolant potentially fix the overheating issues?'
Note: the mechanic could get it to run within the normal temperature range, but it would start overheating as soon as I would take it home.
Jul 14, 2022 at 10:49 AM
