Cannot figure out the cause of our car overheating. Replaced radiator cap, head gasket, temperature sensor, radiator, fan relay, and thermostat. The fan does turn on around 200-210 degrees. Seems worse when we have the fan on in the car, which seems weird. Air conditioning does not work, low coolant and leak somewhere we never bothered to fix. Thought about the cam sensor and doing a pressure test. Any other suggestions?
Jul 18, 2019 at 4:50 AM
