Engine overheating. Just changed the radiator cap. No heat! When A/C is on it smells like vinegar. Reservoir still full.
Mar 25, 2018 at 5:49 AM
✓Experienced Mechanic
Good afternoon.
When it overheated, did you turn it off and wait until it cooled down?
Does it continue to overheat and/or smoke out the tail pipe?
The no heat issue may be from either air in the system, low coolant or a failed head gasket from the overheating.
The smell with the AC on may be from a leaking heater core. Coolant may be in the case and the AC is blowing coolant as well as cold air.
Mar 25, 2018 at 7:05 AM
NORAKOKOSKA
MEMBER
Yes I did.
It does continue to overheat after driving again.
Mar 25, 2018 at 7:13 AM
Okay, thanks. At this point I would not drive it at all. you may have damaged the head gaskets already from the constant overheating.
In order to determine if they are bad, a test called a leak down test needs to be performed where air is added to the cylinders one at a time and watch for coolant movement out of the radiator at the cap.
