Overheating when the heater is on
150,000 MILES • 2.2L • 4 CYL • AUTOMATIC
TINA PAYNE
I have an overheating problem. I put in a new thermostat and a flush, checked the heater core and it working. My car only seems to be overheating when the heat is on in my car. otherwise it runs at normal temperature.
Dec 23, 2016 at 9:09 PM
HMAC300
  • 48,601 POSTS
have cooling system pressure checked for leaks it may be a head gasket problem.
Dec 23, 2016 at 9:44 PM
TINA PAYNE
It was pressure checked for leaks. Found a pin hole in the lower radiator hose. Replaced it.
Dec 23, 2016 at 9:54 PM
HMAC300
  • 48,601 POSTS
check radiator for cold spots if you feel any then the radiator is no good it should be warm all over. do this with car shut off and fans disabled. then get the chemical tester from auto parts for a head gasket. also, check radiator cap it may be losing pressure.
Dec 24, 2016 at 12:58 AM
