Overheating
50,000 MILES • 3.0L • V6 • FWD • MANUAL
DANIEL RAWLS
I have just recently replaced my whole engine with A jdm everything works fine except when I try to go on the high for a long distance drive the car starts to overheat
Sep 14, 2016 at 1:09 AM
HMAC300
  • 48,601 POSTS
check for a blockage or thermostat not working or a radiator bad, check for cold spots on radiator if you feel any it is bad should be same temperature all over.
Sep 14, 2016 at 2:38 AM
