my car has been using a little water/antifreeze every day, not much. other day it overheated due to bottom hose coming loose on radiator. Fixed hose added water then it overheated again. I changed the thermostat then found out the radiator blew. I changed the radiator. Still overheating not at an idle, but once you start going down the road heats right back up with fans going.
Jun 29, 2017 at 12:07 AM
