Overheating
115,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MTORRES227
It will overheat if A/C is off, what can it be? I. Checked relays, they're fine, new water pump, hasn't been overheated.
Feb 23, 2022 at 8:13 PM
WENDY W
  • 86 POSTS
Hello!
It sounds like at least one of the cooling fans may have failed or may not be energizing whenever the air conditioning is not switched on. There also could be a problem within the cooling system circuits that is preventing the fans from running.
Here are a couple of repair guides and a video tutorial that may help you further diagnose the overheating issue:
https://youtu.be/Hlna_kUt7As
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
I've attached a schematic for the cooling fans and relays, along with removal and installation instructions for the cooling fans, if needed (below).
Please let us know what you find.
Thanks, Wendy W
Feb 24, 2022 at 5:26 AM
