Overheating
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAYTHOLEN
Overheating when idling and A/C starts blowing warm. Not steaming.
Changed thermostat, ran with A/C on 45 minutes. Ran cool, A/C fine.
Drove 20 miles , again overheating - A/C warm. Radiator fans both blowing (right one making noise). No leaks, top and bottom hoses both hot.
Jun 16, 2021 at 2:45 AM
Let's start with the overheating issue and then we can check the A/C for an issue. It may just has a weak charge but the overheating is clearly affecting it and it may be shutting the compressor off to keep it from overheating more.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
I am concerned with the fan making noise but the fact that they are on is a good thing.
So let's check coolant level and then pressure check it just to make sure there are no leaks. I understand you see no external leaks but the pressure test will confirm this.
https://www.2carpros.com/articles/radiator-pressure-test
Let's start with this and go from there. Thanks
Jun 17, 2021 at 12:45 PM
