Still overheating after replacing the water pump, thermostat, radiator cap, top hose and flushed the radiator?
1993 MERCURY SABLE
86,000 MILES • 3.0L • 2WD • AUTOMATIC
SHALISA ISHAM
My car is still overheating. I have changed the water pump, thermostat, radiator cap, top hose and flushed the radiator. It still runs hot. I am out of ideas, so any help is appreciated.
Jul 19, 2018 at 2:00 AM
Good afternoon.
From constant overheating, you may have damaged a head gasket. Head gasket failure is a result of overheating. You may have found the original reason for the overheating but in the process, it may have damaged a head gasket.
To confirm, you need to do a leak down test. That is where you inject air into each cylinder and watch for any movement in the radiator. That will confirm whether you have a failed head gasket. You can rent a tool at a parts store for this test.
Jul 19, 2018 at 3:40 AM
