Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Engine
Symptoms
Overheat
Overheating
1998 DODGE INTREPID
1,000,000 MILES • 1.4L
DENNIS BAZZELL
MEMBER
1 POST
Overheats when driven but not idling.
Oct 18, 2019 at 2:22 AM
Experienced Mechanic
Good afternoon,
This could be a clogged radiator. You need an infrared light to test the temperature of the upper part of the radiator and then the lower part. There needs to be 40 degrees difference between the top and bottom.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Oct 18, 2019 at 3:29 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
