Starts overheating at their cranking and running?
2.2L • AUTOMATIC
ROBERT_1
Starts overheating at their cranking and running for a little after cranking it up then I can cut it back off and take the radiator cap off and then put it back on and can crank it and it will run fine for a little bit then start back up
Nov 4, 2026 at 4:52 PM
  • 55,673 POSTS
Hello, please do not remove the radiator cap while the engine is hot—even after shutting it off. Pressurized coolant can spray out and cause severe burns. Let the engine cool completely first. Can I ask if you hear the radiator fan running also, how long does it take before it overheats? Also, do you see any coolant leaks under the car? Here are two guides to help us get started fixing the issue.
https://2carpros.com/articles/engine-overheating-or-running-hot/
and
https://2carpros.com/articles/symptoms-of-an-overheating-engine/
Upload a short video of the problem you find so I can see what is going on.
Nov 5, 2026 at 10:02 AM
