HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Overheat
Overheating
BERNARD1369
MEMBER
1998 HONDA CIVIC
1.6L
4 CYL
2WD
AUTOMATIC
188,000 MILES
I have replaced the radiator. Thermostat, water pump, the sensor on thermostat housing and still getting hot. Help!
Monday, August 21st, 2017 AT 5:08 PM
KEN L
MASTER CERTIFIED MECHANIC
It sounds like you may have a blown head gasket.
Here is a guide that can help you confirm the problem:
Please run this test and get back to us so we can keep helping you.
Cheers, Ken
SPONSORED LINKS
Tuesday, August 22nd, 2017 AT 2:37 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Why Does My Car Overheat After Getting Off The Freeway
Recently, About A Month Ago I Replaced The Radiator In My Civic Because The Radiator Had A Hole That Had Started To Spew Coolant. Other...
Asked by
kickjon1985
1 IMAGE
1998
HONDA CIVIC
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Car Overheating
Car Started Running Hot. Eventually Blower Head Gasket. Have Replaced Head Gasket, Heater Core, Thermostat, It Still Runs Hot But For Some...
Asked by
Bhibberts
1998
HONDA CIVIC
Car Overheats Every Now And Then.
So Ive Replaced The Radiator Cap, Thermostat, And The Water Pump And The Car Still Overheats. The Problem Is It Overheats Every Now And...
Asked by
l2wo4our
1998
HONDA CIVIC
1998 Honda Civic Engine Overheating
Engine Cooling Problem 1998 Honda Civic 4 Cyl Two Wheel Drive Automatic My Engine Goes Overheating And The Funny Part Which I Don't...
Asked by
sef_cha
1998
HONDA CIVIC
1998 Honda Civic Car Starts To Overheat At Idling
Hi I Am Not Sure If Anyone Have Similar Problem Like Mine Or Not, I Have A 1998 Civic With 122k Miles. Everytime The Car Idles For About 4...
Asked by
1998civic
1998
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Online car repair manuals
