Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Yukon
Engine
Symptoms
Overheat
Overheating
2007 GMC YUKON
214,419 MILES
POPPA DUNNIGAN
MEMBER
My SUV is an XL. Overheating when parked and running but not when I drive for hours?
Apr 8, 2019 at 3:16 AM
Experienced Mechanic
Good afternoon,
Are the cooling fans working when it is at idle? If they are not, it will overheat at idle and not at higher speeds.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Apr 8, 2019 at 4:20 AM
POPPA DUNNIGAN
MEMBER
I just brought a brand new fan and it still does it.
Apr 8, 2019 at 4:27 AM
Does the fan turn on?
Apr 8, 2019 at 4:41 AM
POPPA DUNNIGAN
MEMBER
I don't think so.
Apr 8, 2019 at 6:48 AM
Okay, do you have a voltmeter or test light to do some testing?
I attached a diagram of the system. Check the two fuses listed for power on both sides with the key on.
Image (Click to enlarge)
Apr 8, 2019 at 6:57 AM
POPPA DUNNIGAN
MEMBER
Sometime it says Stabilizer off, then overheats when parked.
Apr 8, 2019 at 11:39 AM
Can you do some checking?
Apr 8, 2019 at 12:26 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
