overheating while driving down road. i change thermostat, change temp senor for gauge. bled coolant system.
Jan 14, 2026 at 8:40 PM
✓Experienced Mechanic
Can you hear the fan clutch kick in when the engine is hot? Also, you can have a plugged radiator either internally or externally. On the outside chance you have a blown head gasket, but lets go over these guides which will tell us what is going on.
