Good morning,
There are many reasons for the overheating. Make sure the coolant level is correct.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/engine-overheating-or-running-hot
The first thing I would do is make sure the thermostat is working. If it overheats, I would change it.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Also, are the cooling fans working? They should come on when it gets to 208 degrees and the when you turn on the A/C the fans should come on.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Images (Click to enlarge)
May 9, 2020 at 8:22 PM
