Overheated, possible heater hose blew?
180,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
ALTHEA MAYBERRY
  • 65 POSTS
I was driving my car listed above today and it overheated but it didn't peg the red line. After I pulled over and opened the hood, I noticed steam coming from the back of the engine. I checked the coolant reservoir, and it has plenty of coolant in it. After I let it cool down for a while, I opened the radiator cap, and it nearly blew the cap off. Luckily, I moved fast enough and didn't get hot coolant on me. However, the radiator was completely empty. I refilled the radiator and was able to make it home without it overheating again. But now there is a puddle of coolant under the car under the back of the engine. I noticed a couple of hoses going across the back of the oil pan and they were wet with coolant. I'm thinking that a heater hose blew, but with my Haynes manual, it's not showing me much. I hope you can help me.
Jan 28, 2024 at 5:40 AM
  • 110,248 POSTS
If the radiator was still pressurized when it cooled, it doesn't sound like a hose failed. Otherwise, there would have been no pressure.
The heater hoses attach to the heater core at the firewall. There are two of them. See pic below. Check to see if they are wet.
Also, you may want to pressure test the system once the coolant is full. This allows you to check for leaks under pressure without the engine running or hot.
Here is a link that explains how to do it:
https://www.2carpros.com/articles/radiator-pressure-test
You will need a pressure tester, but most parts stores will lend one to you.
Let me know what you find.
See pic below.
Jan 28, 2024 at 12:45 PM
ALTHEA MAYBERRY
  • 65 POSTS
Thanks for your reply. I appreciate everything 2CarPros has helped me with on all the vehicles I asked for help with. However, thinking about it, I should have told you about how the car acted when I turned on the heater last week to defrost my windshield.
I was sitting in the parking lot at the grocery store and the windows were fogging up. I turned on the heater and as the car was idling, the temperature gauge began to rise above the halfway mark after a few minutes. Normally, the temperature gauge is at one mark below the halfway mark.
Then a couple of days later, my son took his dad (Marty) to the store and the engine began getting hot. After they returned, they let the engine cool off, and Marty pulled the radiator cap off. With it came a big string of junk. Marty said that by turning on the heater, a bunch of junk came out of the core and plugged up the return line for the reservoir and there was very little coolant in the radiator. However, there was plenty of coolant in the reservoir. Marty also said it looked like someone put Stop Leak in it at one time, judging by the string of junk. I wouldn't use Stop Leak if you gave me the how corporation.
So, this brings me to a couple more questions. Could whatever junk come out of the radiator have also clogged the system elsewhere, like at the thermostat? Also, you said it would still be pressurized because it blew the radiator cap off and spit coolant when I loosened it. So, what could cause it to steam at the back of the engine and coolant dripping from underneath?
When I flushed the cooling system over last summer, I forgot to do the heater core. I guess I was in a hurry to get the car running and registered so we could start driving it since we had no transportation at the time.
The last time something like this happened it cost us a $3K garage bill because of melted engine cover gaskets. Since I had never seen an engine like this, I was scared to DIY it. I'm an antique car DIYer. I won't do anything newer than 1989.
Jan 28, 2024 at 11:24 PM
  • 110,248 POSTS
As far as what you found in the system, that could be from corrosion, or someone may have mixed two different types of coolant together that shouldn't be mixed.
Is it possible for you to take a few pics of what was found and upload them for me to see? Also, if you found that in the system, you should be able to flush it again. This time, consider flushing the engine block and heater core as well. The thermostat will be removed to flush the engine block, so you can check it at that point. Additionally, run water through the hoses to make sure nothing is plugging them.
Jan 29, 2024 at 10:42 AM
ALTHEA MAYBERRY
  • 65 POSTS
Hi Joe. I ordered a cooling system pressure testing kit from Amazon and did the pressure test yesterday. There is definitely a break in the system. It's located behind the intake manifold. What does the shiny pipe go to? There is a hose right beside it. That is the general area where the leak is occurring. It's either the pipe or the hose that's broken. Even with my small hands, it's hard to get to, so I'll have to do some dismantling to get to it. I'm including a photo. The blue circle shows the general area where the leak is occurring.
Feb 1, 2024 at 12:09 AM
  • 110,248 POSTS
Don't you love how much room you have to work with? It is frustrating at times.
It's hard for me to see anything in the picture. If you don't have one, get yourself a mechanic mirror at the local parts store. They aren't expensive. Then, you can fish it down between things to help locate the leak. I usually put the mirror where I want it and then shine my light on the mirror so that it reflects off the engine. That way I can see things.
I don't know if there is an AutoZone near you, but they have one that is very inexpensive. See pic below.
See pic below.
Feb 1, 2024 at 10:09 AM
ALTHEA MAYBERRY
  • 65 POSTS
Hi Joe. No AutoZone here, but I do have access to O'Reilly's. Thanks for the advice. I had to turn on my phone's flashlight just to get what was showing in the pic.
Feb 1, 2024 at 10:53 AM
  • 110,248 POSTS
You are very welcome. They should have something similar. I have no idea why everything needs to be so tight. My favorite is having about 2 inches to work behind the engine and under the cowl on many vehicles. To add insult to injury, rather than using a hex nut or bolt, a torx is used and it is nearly impossible to even determine the size needed. LOL
Regardless, let me know what you find or if I can help.
Feb 1, 2024 at 11:11 AM
ALTHEA MAYBERRY
  • 65 POSTS
Hi Joe, I have some more info for you about my Acura. I just came from outside. I removed, what I am going to call, a body brace. It's a bent bar with a diameter of approximately 1". It spans from fender-well to fender-well and is attached to the back firewall. Anyway, that allowed me to get a better look at things down there, that and removing the fuel injection cover on the driver side. I purchased a diagnostic mirror from Walmart for $4.98, which also helped me to see things better.
There is a hose, about the diameter of a heater hose, coming out of the back of the motor from the driver's side. With the mirror and a flashlight, I could see that the hose was wet. It's positioned just below the driver's side fuel rail. With my hand, I was able to trace the hose to see where it led. It goes directly behind the intake manifold and plugs into something else, which I couldn't see very well, so I don't know what it is. I was able to tell approximately how long the hose was as I could feel the hose clamps on each end. I think it is between 2 - 3 feet long.
However, to be able to remove the hose, I will have to take part of the fuel rail off as well as some kind of canister that the fuel rail plugs into. The canister is attached to the firewall. There is also some other junk back there that is in the way, I have no clue what it is. It looks like some kind of linkage, but I don't know what it goes to. Maybe it's for the transmission.
Even though it's a front-wheel drive, the engine isn't transverse. Being that it's a Japanese-built car I haven't got a clue what they were thinking when the engineers designed this thing. I wish I could get the wiring done on my 85 Dodge D150 Ram Truck. It's so much simpler than this Japanese thing. No prejudice intended against the Japanese, I'm just not much for foreign cars. I'll drive'em but I don't like fixin'em. I'd be focusing on the wiring on my truck if the Acura would quit breaking itself.
I look forward to your reply,
Althea
PS. I was looking in my Haynes Manual last night, page by page, and I finally found something that made sense. I'm including a photo. The hose that is highlighted I believe is the culprit.
Feb 8, 2024 at 3:28 AM
ALTHEA MAYBERRY
  • 65 POSTS
Hello again Joe. I also need to know where to relieve the pressure on the fuel rail. To get to the hose I need to replace, I have to take off the part of the fuel rail that follows along the back of the engine. Can you get me a photo of the pressure release so I will know where it is? If you can, I'd be most grateful.
Feb 8, 2024 at 5:51 AM
  • 110,248 POSTS
The pressure release is done at the fuel filter. Basically, you would wrap a shop towel around it and loosen the service bolt on it.
I attached the directions below.
Let me know if this helps.
Feb 8, 2024 at 7:07 AM
ALTHEA MAYBERRY
  • 65 POSTS
Hello Joe,
I guess I missed the point of your last post. It just wasn't clicking in my mind or something. I ended up letting the fuel pressure off at the gas tank, in the trunk, under the floor. This car has got me so frustrated, it's pathetic. I wish I could be working on my 85 Dodge D150 instead. Only if this car would quit breaking down on me.
Anyway, I finally got enough stuff out of the way that I can see the hose I'm trying to get to better. Now my big problem is the transmission dipstick tube is in my way. I've been examining how to get the tube out of my way all day long. I even jacked up the car and tried looking at it from beneath. There is a bracket just above the end of the hose, highlighted pink, that attaches to the rear water outlet in the attached photo. I thought that the transmission linkage was connected to this bracket, but it turned out to be some hard-line vacuum tubes, and the transmission dipstick tube.
I loosened the lines and dipstick tube from the bracket. The lines are out of the way, but I can't get the dipstick tube to move more than .25 inches in any direction. The main bracket is attached to the top of the back of the head. I am prevented from getting to the bolt that holds the main bracket to the head until the dipstick tube is out of the way. If I can get that bracket and the tube out of the way, then I can reach the hose clamp.
As you can see, I have circled in red the rear water outlet, which I thought was under the intake manifold, but it turns out that it's attached directly to the back of the head. It looks as though the outlet can be removed. All I know is this is the area where the coolant is leaking from. However, with the way the parts in the photo are set up, I can't figure out where the inlet and outlet hoses attach to the firewall. This car makes no sense to me.
The main thing is getting the transmission dipstick tube out of the way. Then I can get to the house.
Thea
Feb 19, 2024 at 6:44 AM
  • 110,248 POSTS
I just went through two manuals and found nothing for the dipstick tube. So, I have to ask. Could you take a couple of pictures and upload them for me to see? If you are able to move it 1/4", I would think it should come out. If there is a bracket holding it in place, it shouldn't move. It should simply press into the housing. There is an O-ring that prevents it from leaking.
Feb 19, 2024 at 12:22 PM
ALTHEA MAYBERRY
  • 65 POSTS
Hi Joe,
I'm sorry, it's way too tight in there and I can barely make heads or tails of it with a flashlight so I couldn't get a pic. However, I found a 91 Acura Legend transmission on eBay and plenty of photos. I downloaded the three best photos to my computer and am uploading them to here. I'll also supply the link where I found it in case you want to see the rest of the photos. The seller tried to do a 360 photo shoot. Here's the link: https://www.ebay.com/itm/332346229881
I hope this helps. I'm so sick of this car, I'm ready to stick a for sale sign on it and let it be someone else's pain in the back side. The only foreign vehicles I ever had that I liked were my 2 89 Isuzu Pickups. I wish I still had one of them.
Feb 19, 2024 at 9:00 PM
  • 110,248 POSTS
Tight? I totally understand. The greatest vehicle I own is a 1978 C-10 Chevy truck with a 6-cylinder. You can fit two people under the hood while working on it. LOL
I looked at the pics and the ones on Ebay. It is somewhat difficult for me to see, but it does appear there is a bolt at the base of the tube where it attaches to the engine block. Are you able to access that one?
See pic below.
Feb 20, 2024 at 10:57 AM
ALTHEA MAYBERRY
  • 65 POSTS
Yes. There is a bolt there, but the question is how do I get to it? I jacked up the car, crawled under it, and literally had to squeeze my hand and arm up to my elbow just to feel for the bolt. It feels like a 10 mm. It's going to be loads of fun getting to it. Also, there is some kind of wiring harness attached at two different places on the tube, which is another thing making it difficult to get to it. I guess all I can do is try. Thanks for all your help. I'll let you know what happens.
Feb 20, 2024 at 11:40 AM
