Overheated lost coolant now it will not start
200,000 MILES • 4WD • AUTOMATIC
TASHA NICHOLE ROBERTS
Radiator hose replacement upper, now it will not start.
Dec 26, 2018 at 10:29 PM
  • 110,251 POSTS
My first concern is how badly it overheated. Under extreme conditions, to could have warped a cylinder head, blown a head gasket.
Regardless, there are many other things that will cause it not to start. First, take a look through this link and see if anything helps.
Next, you need to have fuel and spark to the engine for it to run. Here are two links that explain how to check for both:
Here are the manufacturer's specs for fuel pressure:
FUEL SYSTEM PRESSURE
339 kPa ± 34 kPa (49.2 psi ± 2 psi).
Lets start by making sure we have spark and fuel. Once that is determined, I'll know which directions to send you.
Dec 27, 2018 at 10:50 AM
