Overheated, cranking but not starting
338,000 MILES • 1.1L • 4 CYL • MANUAL
YVETTE NEETHLING
Whilst driving the car overheated (no warning light), the tappets made a terrible noise, drove with the noise for about 5km's, then there was a loss of power to the point of the engine shutting down. Smoke came from the engine, waited a few minutes, filled up with water, didn't want to start. I then took off the battery terminal for a few minutes, reconnected it and it still didn't start. Checked for leaks, nothing, replaced the radiator cap a few days prior and the old one was worn and caused overheating. Two days later and the engine cranks but doesn't want to start.
Oct 20, 2020 at 7:33 PM
Good morning,
This sounds like you may have damaged the head gasket in the engine from the overheating.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Coolant may have entered the engine and that damaged the engine itself.
I would start with a compression test to see if there is any compression for the engine to work.
Oct 20, 2020 at 9:00 PM
