Overheated? 50/50 pre-diluted antifreeze coolant ?
148,000 MILES • 3.6L • V6 • AUTOMATIC
OAKTOWN-66
My car overheated and my daughter put in the peak 50/50 pre-diluted antifreeze coolant Global lifetime. I'm not sure if that's the correct one but do I have to flush it out or could I just add to it?
Mar 20, 2023 at 9:35 AM
  • 55,740 POSTS
You should be okay; can I ask if you fixed the problem of overheating? Did the radiator fans come on or was the thermostat stuck? These guides can help:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Please go over these guides and report back.
Mar 20, 2023 at 10:47 AM
