So I had my timing belt go out and fixed it with my uncle. Car drove fantastic, on the way home the car shut down. The gauges never showed it running hot but it did.appears the thermostat stuck and the radiator blew. So I assume the head gasket is probably toast. Tried to crank it and it turns over but wouldn't crank. I didn't see any water in the oil but I figured it still had a blown head gasket. After turning it over a million times I did get it to run.ran badly tho.so I got the number of a guy who is supposed to know a lot about Chrysler's and he told me the car will shut down if the thermostat doesn't open and I should replace the thermostat and try and crank it again. Now the car has sat for about 7 months now and I was wondering if I change the plugs, oil, thermostat and new radiator if this guy is right and the car will run fine? Or should I just invest in another motor. Car is one of the better looking at cruiser with heated seats and power everything. What is your opinions. Thanks in advance.
Jan 18, 2020 at 1:14 PM
