Overheats at idle
301,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
GEOFFPEARL
  • 31 POSTS
My air conditioning was not working and I fixed it. Now the car overheats at idle. Cools off immediately once I press on accelerator (in gear or neutral).
May 27, 2020 at 1:39 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
First thing we need to check is the coolant level, if the level is low it will have the systems you have described. The other thing we need to check is if the radiator fans are coming on when you turn on the A/C. If you could check these 2 things and let us know the results we can help you pinpoint the problem. We look forward to hearing back from you with the results and thank you for using 2CarPros!
May 27, 2020 at 9:03 PM
  • 55,808 POSTS
This guide can help you find the problem as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please let us know what you find.
May 28, 2020 at 8:47 AM
GEOFFPEARL
  • 31 POSTS
I filled up the radiator with about half a jug of coolant and so far so good. I let it idle for just a couple minutes and the temperature didn’t rise. I will be able to check again tomorrow.
May 28, 2020 at 11:03 AM
  • 55,808 POSTS
Can you turn the air conditioner on to see if the cooling fan come on? It can take about 2 minutes to happen. Please let us know.
May 29, 2020 at 4:18 AM
GEOFFPEARL
  • 31 POSTS
Yes. When i turned on the AC the cooling fans turned on. Then shut off AC and the cooling fans turned off.
May 29, 2020 at 5:51 AM
  • 55,808 POSTS
Perfect. does the A/C blow cold? this is the normal operation of the fans, one can come on at a time.
May 30, 2020 at 4:02 AM
