Overheating
183,482 MILES • V8
ROVON
My temperature gauge goes up after I drive maybe a block or to and I pull over it drops midway. It constantly does this goes up and then drops after I pull over for 5 minutes. There is no smoke under the hood or the back tailgate.
Jun 8, 2020 at 1:19 AM
Good morning,
This could be a thermostat that is bad or a clogged radiator that is not allowing circulation.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Check your fluid level to be sure it is not low.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Removal
1. Drain the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding.
2. Remove the thermostat housing.
3. NOTE: Thermostat can be rotated in either direction to release it from the thermostat housing.
Using a 18 mm (0.7 inch) open end wrench, simultaneously push down and turn the thermostat retainer to release it from the housing.
4. Remove the thermostat spring, thermostat main spring and the thermostat element.
Installation
1. CAUTION: When installing the thermostat into the thermostat housing, make sure to align the thermostat pin with the hole in the housing.
Position the thermostat into the thermostat housing.
Be sure to install the small end of the thermostat spring toward the thermostat housing.
2. CAUTION: After installing the thermostat into the thermostat housing, make sure that the tabs on the thermostat retainer are locked into the tabs on the thermostat housing.
NOTE: The thermostat can be rotated in either direction to install it in the thermostat housing.
Using an 18 mm (0.7 inch) open end wrench, simultaneously push down and turn the thermostat retainer to install the thermostat in the housing.
3. Install the thermostat housing.
4. Fill and bleed the cooling system.
Jun 8, 2020 at 1:27 AM
